Форумы » Работа с оборудованием » Прочее оборудование » What is the Half Ball (0.5) Handicap? How to Play and Win at M88
30.08.2025, 03:51 | What is the Half Ball (0.5) Handicap? How to Play and Win at M88
In the world of Asian handicap betting, the Half Ball Handicap (also known as 0.5 handicap) is one of the most common and attractive markets. With this type of bet, the stronger team gives the weaker team a half-goal advantage, making the wager both exciting and easy to understand. But do you really know how the Half Ball Handicap works? In this article, wintips will break down the rules of this market and reveal the most effective strategies to increase your chances of winning when betting on the 0.5 handicap at M88.
What is Draw No Bet? Characteristics of the Level Ball Handicap
Draw No Bet, also called “Level Ball” or 0 handicap, is an Asian handicap where neither team gives a head start. This means no side is considered stronger, and you bet under less pressure compared to other handicap lines.
best online bookmaker like M88 usually offer DNB bets when two teams are evenly matched in terms of squad strength and form. Personally, I find this to be the easiest Asian handicap to play, making it ideal for beginners.
If the match ends in a draw, your stake is refunded → you neither win nor lose.
If the team you back wins, you win the bet.
If the team you back loses, you lose your stake.
This simple rule is why Draw No Bet is one of the most straightforward betting markets available.
Rules for Winning and Losing in DNB
If the match ends in a draw → All bets are void, and your stake is refunded.
If one team wins → Bettors who picked the winning side win their bets; those who backed the losing side lose their stakes.
See more: top 10 betting apps in uganda
How to Bet Draw No Bet for Maximum Profit
At M88, betting DNB is just as profitable as other football wagers. Here are the three methods I personally use to maximize winnings:
Bet on the Home Team
Home teams often perform better with fan support and home-ground advantage. If the two sides are evenly matched, backing the home team is usually a safer option.
Bet on the Team in Better Form
Teams with strong recent performances tend to play with higher confidence. I often back the in-form team when playing DNB.
Bet on the Team with Better Head-to-Head Record
Analyzing past encounters between the two teams can give you an edge. Choosing the side with a stronger head-to-head record improves your chances of winning.
Key Tips to Never Lose with DNB Betting
Although Draw No Bet is simple, you shouldn’t underestimate it. Here are important tips to ensure success when playing this market at M88:
Research and analyze matches carefully
Don’t place a DNB bet on every match. Instead, study both teams’ form, tactics, and head-to-head records before wagering. Detailed analysis will help you choose the stronger side.
Choose a trustworthy bookmaker
Many unlicensed bookies may scam players by blocking withdrawals or canceling winnings. That’s why it’s crucial to bet only with reputable operators. Personally, I recommend M88, one of the most reliable bookmakers in the world. At M88, you can bet not only on football but also on other sports like basketball, tennis, badminton, and volleyball—always with peace of mind.
Final Thoughts
Now you know exactly what Draw No Bet (Level Ball Handicap) is and why it’s so popular. Thanks to its simple rules and fair play, it has become one of the most attractive Asian handicap bets at M88. By applying the knowledge and strategies above, you can place your wagers with confidence and maximize your chances of winning.
Текущее время: 10:27. Часовой пояс GMT.
