Форумы » Работа с оборудованием » Прочее оборудование » What is Odd/Even Betting? Winning Strategies for Odd/Even Football Bets at M88
29.08.2025, 03:58 | What is Odd/Even Betting? Winning Strategies for Odd/Even Football Bets at M88
Odd/Even betting is a relatively new type of wager offered at bookmaker M88. Since it’s still unfamiliar to many players, not everyone knows exactly what Odd/Even betting is. In this article, wintips will break down how Odd/Even football bets work and share some useful strategies to help you win and make profits from the bookmaker.
What is Odd/Even Football Betting?
Odd/Even betting is based on the total number of goals in a match, similar to Over/Under betting. However, instead of predicting “Over” or “Under,” you only predict whether the total goals scored will be odd or even:
If you bet on Even and the final total goals are 0, 2, 4, etc., you win.
If you bet on Odd and the total goals are 1, 3, 5, etc., you win.
In Odd/Even betting, it doesn’t matter which team wins or loses — the only thing that matters is whether the total number of goals is odd or even. The winning probability is almost 50/50, making it one of the simplest ways to earn money at the best betting site in the world M88.
Popular Types of Odd/Even Bets at M88
Match Goals Odd/Even
Predict whether the total number of goals scored in a match is odd or even. You can choose to bet on the first half, second half, or full match.
Team Goals Odd/Even
Bet on whether the goals scored by a specific team are odd or even. Again, you can select first half, second half, or full match.
Corners Odd/Even
Predict whether the total number of corner kicks in a match will be odd or even.
Cards Odd/Even
This market counts disciplinary cards given by the referee. Yellow=1 point, Red=2 points. The total points are added up, and you bet on whether the final number is odd or even.
Penalty Shootout Odd/Even
If a match goes to penalties, you predict whether the number of successful penalty kicks will be odd or even.
How to Calculate Winnings in Odd/Even Bets
For example, in a match between Man United vs Chelsea, M88 sets the following odds:
Even: 1.98
Odd: 1.90
If you bet 1,000,000 VND:
Betting on Even: If the result is even, your payout is 1,000,000 x 1.98=1,980,000 VND.
Betting on Odd: If the result is odd, your payout is 1,000,000 x 1.90=1,900,000 VND.
Tips for Winning Odd/Even Football Bets
Analyze Team Form
Study the current form and scoring ability of both teams. This helps you better predict the likely number of goals.
Bet Small on Odd/Even
Treat Odd/Even betting as a side market. Don’t stake large amounts; instead, use small bets to boost your overall profit.
Maintain a Good Mindset
Staying calm and disciplined increases your chances of making the right choice when betting on Odd/Even.
Check Head-to-Head Records
Past meetings between the two teams often reveal trends. If matches between them usually end with odd totals, betting on odd could be the smarter choice — and vice versa.
Final Thoughts
Odd/Even betting at M88 is simple, fun, and offers a 50% chance of winning. By understanding the rules and applying the right strategies, you can turn this market into a reliable way to earn profits. Hopefully, the experience and telegram tips football shared above will help you place smarter bets and make the most out of Odd/Even betting at M88.
Текущее время: 06:28. Часовой пояс GMT.
