Форумы » Работа с оборудованием » Прочее оборудование » Throw-in Handicap Betting: What It Is and Winning Tips You Should Know
18.04.2025, 03:55 | Throw-in Handicap Betting: What It Is and Winning Tips You Should Know
The throw-in handicap bet is considered a special side bet that adds extra excitement to betting boards offered by reputable bookmakers. This type of bet is directly related to the number of throw-ins taken by both teams during a match. So, what exactly is the throw-in handicap bet, and what are the top tips for playing it effectively? Let’s explore it in detail with https://wintips.com/.
What is a Throw-in Handicap Bet?
In football, every match involves throw-ins — used to restart the game when the ball goes out of play on the sidelines.
The throw-in handicap is a secondary bet type in the most aggressive footballers. It gives punters more options and increases the chance of winning. Reputable bookmakers will provide clear handicap lines for players to choose from. The outcome is determined by the total number of throw-ins taken by either the home or away team in a match.
Common Types of Throw-in Handicap Bets
Throw-in handicap bets have become increasingly popular among top bookmakers. This type of bet usually comes in three main forms:
1. First Throw-in Handicap
In this bet, you predict which team — home or away — will take the first throw-in of the match. Since it’s often based on luck, the win rate is around 50/50.
2. Over/Under Throw-ins
This is similar to corner or card betting. The bookmaker will analyze past statistics and offer a projected number of total throw-ins. You can then choose:
Over (Over the line): You win if the total throw-ins exceed the bookmaker's prediction.
Under (Below the line): You win if the total is less than the predicted number.
Exact match: If the total throw-ins equal the predicted number, the bet is a push, and your stake is refunded.
3. Throw-in Handicap Betting
This variant requires deeper analysis. You assess which team is likely to have more throw-ins, or whether their throw-in stats are quite balanced.
In this case, your bet is based on the total number of valid throw-ins taken by both teams. If your selected team has more throw-ins (after applying the handicap), you win. There are three possible outcomes:
Win full amount
Win half your stake
Push (refund)
What Counts as a Valid Throw-in?
To bet on this market effectively, you must understand which throw-ins are valid and which are not. Here are three key scenarios:
Throw-ins resulting in fouls (e.g., incorrect technique) still count toward the total. Even if the throw is retaken, it still counts.
Throw-ins during extra time or injury time are not included in the bet.
All throw-ins taken from the sidelines to restart normal play during the first and second halves do count.
How to Increase Your Chances of Winning Throw-in Handicap Bets
To maximize your chances of winning in this market and identify valuable betting opportunities, follow these key strategies:
1. Pick the Stronger Team
Stronger teams usually dominate possession and create more attacking plays. This puts pressure on the opponent, who will often be forced to clear the ball out of bounds, leading to more throw-ins for the dominant side.
2. Understand Each Team’s Playing Style
The tactics and strategy of each team can greatly influence the number of throw-ins. Teams that apply high pressure or use wide play frequently cause the ball to go out of bounds more often — resulting in a higher number of throw-ins.
3. Evaluate Surrounding Match Factors
Important match context — such as promotion, relegation, or title contention — often causes teams to play more cautiously. This affects ball control and clearance decisions, which in turn impacts the number of throw-ins.
That wraps up everything you need to know about the throw-in handicap bet, including betting methods and key factors to consider. If you want more insights, odds breakdowns, or throw-in betting tips, visit a reputable bookmaker that offers generous promotions and reliable stats.
Good luck, and may your throw-in bets bring big wins!
Текущее время: 03:07. Часовой пояс GMT.
