Форумы » Работа с оборудованием » Прочее оборудование » What Is the 3-Way Handicap Bet (3W Handicap)? How to Play Effectively
12.04.2025, 04:14 | What Is the 3-Way Handicap Bet (3W Handicap)? How to Play Effectively
Among the many emerging football betting markets, the 3-Way Handicap (3W Handicap) is quickly gaining popularity among bettors.
In this article, bet win tips will help you better understand how the 3-Way Handicap works and how to play it effectively.
What Is the 3-Way Handicap Bet?
The 3-Way Handicap (3W Handicap) is a variation of the traditional Asian Handicap. While they share many similarities, there are some key differences.
In the 3-Way Handicap:
Only whole number handicaps (e.g., -1, -2, -3) are offered.
There are no decimal handicaps like -0.25, -0.5, or -0.75 as you would see in Asian Handicap markets.
This type of bet is mentally challenging and requires good analysis.
Currently, bookmakers online offer the 3-Way Handicap across different types of bets:
You can wager on the full match or just one half.
Some bookies also combine this market with Over/Under bets for more variety.
How to Play 3-Way Handicap for Beginners
Playing the 3-Way Handicap isn’t too complicated, even for newcomers. However, many players still struggle to use it effectively.
Let’s look at an example to better understand how this bet works:
Example:
Liverpool vs. Watford (English Premier League)
You bet 100,000 VND on Liverpool -2 handicap.
Determine the outcome based on the score difference:
Liverpool’s goals=A, Watford’s goals=B
A - B=2: The result is a draw, and your stake is refunded.
A - B < 2: Watford wins, and you lose the bet.
A - B > 2: Liverpool wins, and you win the bet.
Key Features of the 3-Way Handicap Market
Offers better odds than many other markets, especially Asian Handicap.
Since the odds are rounded to whole numbers, the chance of a stake refund is higher.
Ideal for high-profile matches or those with a clear skill gap between teams.
Higher potential rewards, attracting many bettors.
Expert Tips for Betting on the 3-Way Handicap
Learning from experienced bettors can be the key to success, especially for beginners.
Like all bet types, the 3-Way Handicap also requires you to understand a few basic strategies.
Here are some expert tips to improve your winning chances and reduce losses:
1. Choose a Trusted Bookmaker
Before betting, make sure you select a reliable and trustworthy sportsbook.
This helps avoid scams and issues with withdrawing winnings.
Also, compare the odds across different bookmakers w88 login for the same match to find the best value before placing your 3-Way Handicap bet.
2. Stay Calm and Collected
Your mental state plays a big role in your decision-making.
Always analyze the match thoroughly before betting.
Avoid letting the opinions of others or the betting crowd sway your choice.
3. Select the Right Matches
Each match has different betting potential.
To minimize risks, choose matchups where one team clearly outclasses the other.
Pro tip: Target matches between a strong and a weak team.
4. Manage Your Bankroll
Betting isn’t just about one match—it’s about long-term strategy.
If you lose one match, you can still make up for it in others—if you manage your funds wisely.
Set limits and follow a clear financial plan:
Total daily betting limit
Maximum amount you're willing to lose in a day
Maximum stake per individual bet
5. Analyze Real-Time Team Conditions
Teams may face external factors that affect performance.
Before placing a bet, consider the following:
Recent form (at least the last 5 matches)
Injuries or suspensions
Coach suspensions
Psychological or mental challenges facing the club or players
These useful tips and insights should give you a clearer understanding of the 3-Way Handicap betting market and help you increase your chances of winning.
Good luck, and bet smart!
Текущее время: 10:00. Часовой пояс GMT.
