Форумы » Работа с оборудованием » Прочее оборудование » What is the Handicap Bet? The Simplest and Most Accurate Way to Calculate It
11.04.2025, 03:43 | What is the Handicap Bet? The Simplest and Most Accurate Way to Calculate It
What is the Handicap bet? Why is Handicap such a popular betting type among football betting enthusiasts? If you want to get into Handicap betting, what essential tips should you have under your belt? Let’s dive in with bet win tips to fully understand this bet and learn how to become a consistent winner at the bookmakers.
The Handicap bet, also known as the Asian Handicap, is a type of bet based on goal difference between two teams. It is widely offered by many bookmakers. Although it attracts many players, not every bettor truly understands how it works.
In simple terms, the Handicap bet is based on goal differentials in a football match. top online bookmaker analyze, calculate, and set these odds to give players the most enjoyable and fair betting experience.
To make the most of your Handicap bets, here are some key tips you should keep in mind:
Choose high-profile matches to bet on
Adjust your betting strategy for each half
Select bets with reasonable and logical odds
Consider using a step-by-step (ladder) betting approach
Basic Types of Handicap Bets in Football Matches
Handicap bets can play out in a variety of situations depending on the match, but here are the most common types:
Draw No Bet – Level Handicap
This type of bet is frequently used in matches with no clear favorite.
0 Handicap (Draw No Bet): Also called “level ball,” this means you’re simply betting on a team to win. There’s no favorite or underdog, and if the team you bet on wins, you win. If the match ends in a draw, your stake is refunded.
0.25 Handicap (Level quarter-ball): Used when there is a slight difference in team strength. The stronger team gives the weaker team a 0.25 goal head start. If you bet on the stronger team and they win, you win. If the match is a draw, you lose half your stake.
0.5 Handicap (Half-ball): The stronger team gives the other a 0.5 goal advantage. If the stronger team wins, you win. If it’s a draw or they lose, you lose your bet.
1 Handicap (One-ball): The stronger team must win by exactly one goal for your stake to be refunded. A win by two or more means you win the bet; a draw or loss means you lose.
2 Handicap (Two-ball): The stronger team must win by three or more goals for you to win the full bet. A two-goal win means your stake is refunded, and less than two means a loss.
Handicap with Greater Goal Differences
These bets involve larger goal spreads:
0.75 Handicap (Three-quarter goal or 0.5–1): If the stronger team wins by 1 goal, you win half your stake. Winning by 2 or more earns you the full payout. A draw or loss means you lose your stake.
1.25 Handicap (One and a quarter goal): The stronger team needs to win by 2 or more goals for a full win. If they win by 1 goal, you lose half your stake. Draw or loss results in a full loss.
1.5 Handicap (One and a half goals): The stronger team must win by 2 or more goals for you to win. A win by 1 goal or any worse result means you lose.
1.75 Handicap (One and three-quarter goals): The stronger team must win by 3 or more goals for you to win. A 2-goal win returns your stake, and anything less is a loss.
With the information above, we hope you now have a clearer understanding of what Handicap betting is and the most common types of Handicap bets. worst goalkeeper in the world cup is a thrilling and exciting experience—why not give it a try when you get the chance? And don’t forget to check out Wintips daily for more betting tips and strategies!
Текущее время: 05:59. Часовой пояс GMT.
