03.04.2025, 03:42 | Football over/under betting
Over/Under betting, also known as O/U or Totals betting, is one of the easiest and most popular types of wagers. Due to its simplicity, many bettors prefer this form of betting. However, new players might not fully understand how Over/Under betting works in football.
In this article, Wintips will guide you through reading Over/Under odds from A to Z and share expert tips from seasoned bettors to help you master this betting format.
What is Over/Under Betting?
Over/Under betting, also known as Totals betting, is a type of wager where the outcome is determined based on the total number of goals scored in a match. This includes the 90 minutes of regular play plus stoppage time (if any) but does not count penalty shootouts.
Unlike other popular betting formats such as European or Asian Handicap betting, Over/Under betting does not require you to predict the winner of the match. Instead, you only need to focus on the total number of goals scored by both teams.
If the total goals exceed the bookmaker's given threshold, the bet is considered "Over."
If the total goals are below the given threshold, the bet is considered "Under."
If the total number of goals equals the bookmaker's set line, the bet is refunded.
Football Over/Under Betting
Besides traditional handicap betting, Over/Under betting is widely favored by many punters. Typically, Over/Under football bets are based on the total number of goals scored in a match, including stoppage time. Some bookmaker 100 also allow betting based on other statistics, such as total fouls, throw-ins, or corner kicks, adding more diversity to this betting style.
Over/Under Betting Based on Total Goals
To understand this better, let’s consider an example:
If a football match ends with a score of 2-1, the total number of goals scored is 3.
If the score is 4-3, the total number of goals is 7.
When placing an Over/Under bet, you don’t need to worry about which team is stronger or who will win. Instead, you bet on whether the total goals will be higher or lower than the bookmaker's given threshold. If the total goals are lower, bet on "Under"; if higher, bet on "Over."
A key point to remember is that goals scored in extra time or penalty shootouts are not counted. Many bookmakers also offer Over/Under bets for the first half, second half, or specific minutes in a match, making the betting experience even more engaging.
How to Read Over/Under Odds for Beginners
Over/Under 0 Goals
This is one of the simplest Over/Under bets:
If you bet on "Over" and the match has at least 1 goal, you win.
If you bet on "Under" and the match ends 0-0, the bet is refunded.
If you bet on "Over" and no goals are scored, you lose.
Over/Under 0.25 Goals
This type of bet is also known as 1/4 or quarter-ball bet.
If you bet on "Over" and the match has at least one goal, you win the full amount.
If you bet on "Under" and the match ends in a draw, you lose half your stake.
If you bet on "Under" and no goals are scored, you win.
Over/Under 0.5 Goals
Also known as a half-goal bet (½):
If you bet on "Over" and at least one goal is scored, you win.
There is no refund option in this bet.
Over/Under 0.75 Goals
Also called 3/4 or half-ball bet:
If you bet on "Over" and the match has 2 or more goals, you win.
If you bet on "Over" and the match has exactly 1 goal, you win half your stake.
If you bet on "Under" and the match has 1 goal, you lose half your stake.
If no goals are scored, the "Under" bet wins.
Over/Under 1 Goal
This is a straightforward bet:
If exactly 1 goal is scored, the bet is refunded.
This format also applies to Over/Under 2 goals, 3 goals, etc.
Over/Under 1.25 Goals
Also known as 1 - 1.5 goals:
If you bet on "Over" and the match has at least 2 goals, you win.
If exactly 1 goal is scored, the "Over" bet loses half the stake.
This pattern follows for Over/Under 2.25, 3.25, etc.
Over/Under 1.5 Goals
Also known as 1 ½ goals:
If the match has 1 or 0 goals, the "Under" bet wins.
This same logic applies to Over/Under 2.5, 3.5, etc.
Conclusion
With this guide, you now have a solid understanding of Over/Under betting in who is the skinniest soccer player in the world. By applying these strategies and expert insights, you can increase your chances of making successful bets.
Good luck, and may you win big!
Текущее время: 06:24. Часовой пояс GMT.
