cecilia55
19.01.2024, 10:59 | grand seiko sbga293 replica
Fuqiao is on the wrist, and the momentum is like the best evaluation of this new red disk
As one of the three primary colors, red is also the first color in the visible spectrum. It has good diffraction ability and has strong visual impact. Therefore, it is often used as a symbol of life, vitality, health, enthusiasm, vitality, and joy. The red is also the background of traditional Chinese culture. It is also more purely represented by festiveness and liveliness every time at the end of the end of the year. During this period, many watch brands will also launch a red disk watch, and Panerai is no exception. Today, a new and enthusiastic new Luminor Due Luminuer series wine red disk watch is launched. The celebration atmosphere of the Chinese Lunar New Year cleverly echoed the Chinese Lunar New Year with outstanding red disks. Then use the real picture below to enjoy with cousins.
One of the advantages of Luminor Due Luminul series watches is that it is created according to the Luminor Lumino watch as a blueprint. While continuing its iconic appearance aesthetic characteristics, the overall control of the watch is more delicate and thinner. The style is also a modern city, which is more suitable for wearing in daily life. This series of models are mainly based on two sizes of 42 mm and 38 mm. The new work uses a 42mm stainless steel pillow -shaped case and is fully polished. Through the surface picture, you can also feel that the shell is more light and thinner.
Jacob & Co TWIN TURBO
replica Richard Mille RM 47
The crown bridge, also known as the "Fukyo", is the most recognisable element of Panerai watches and is meant to bring good fortune and good fortune to collectors. This device is located on the right side of the case, and like the case, it is also fully polished, from the bridge to the lock lever, which is more visually holistic and highlights its roundness. In fact, last year, it can be seen that Panerai attaches great importance to the color of the plate, and in August, a set of dopamine "Pei" color color plate gave the Luminor Due series a special vitality. At the Swiss Watch Show at the beginning of the year, an attempt was made to bring back the red dial design on the Leidmir Annual Calendar. Red itself is a rare choice for Panerai to choose a coloured panel.
Before that, if you want to buy the red Panerai, there is still a certain threshold, until Panerai launches this PAM01424. In terms of the physical effect of the watch, in the past, the red plate was often associated with sports watches, after all, this color represents passion, but after Panerai's blended burgundy plate, enthusiasm is also delicate style, and at the same time, the tone is rich enough, Panerai has also made a gradient effect on the plate, the burgundy gradually deepens from the center to the edge to black, and then superimposed with the sunburst decoration, so that the plate will also change with the light and shadow effect.
Through the macro lens, you can see that the burgundy plate has extremely fine grains, which is extremely textured. Panerai has also taken into account every detail in the design, such as the date window at 3 o'clock, and the date background color is the same color as the burgundy plate, so as to avoid the window opening to destroy the overall beauty of the plate.
Best replica watches
replica watches on sale
At 9 o'clock, the dial features a small seconds dial with the iconic torpedo small seconds hand.
The watch also uses the iconic skeleton sandwich dial, with the upper dial openworked out to create the hour markers, and the lower dial and hands filled with Super-LumiNova™ paint, so that the watch can be read in a green glow-in-the-dark environment in low light. The picture above shows the actual effect of the watch's luminous glow.
Inside the brushed stainless steel caseback, the watch is equipped with a P.900 automatic movement, which is mainly slim and only 4.2 mm thick, while a single barrel can also provide a long power reserve of 72 hours in 3 days after a full chain, which is the same as a weekend watch, and the P.900 also has excellent performance in maintaining accuracy and durability.
It comes with a black alligator leather strap with an adjustable clasp in polished stainless steel. The quick-release system at the junction between the strap and lugs can also be clearly seen on the case back, which makes it easy to change the strap at the touch of a button.
This Panerai new Luminor Due Lulinu Du Duer series wine red disk watch PAM01424. In general, it is as always implemented by Panerai. The dislocated wine red plate is incorporated, so that the watch presents the retro and modern characteristics. The changing style of the watch is not related to the red color itself, and it also gives the watch a stronger expression. Make it stand out from the new colored watches. I personally like the disk modification effect of this watch. When it shines with light, the solar pattern presents layered changes at different angles. Just looking at the disk is a pure visual enjoyment. The watch experience is also good as ever. After the conventional diameter is slowly returned to the mainstream surface size, 38 mm, 40 mm, and 42 mm are also more popular with Pei fans. The watch price of the watch is 55,200 yuan. This new work starts exclusively in the Chinese market since January 2024. It is only available in Panerai Stores. Interested cousins ​​may wish to go to the store to try to wear experiences. One year is red.
replica Ulysse Nardin Watches
replica Bell & Ross watches
cecilia55 вне форума   Ответить
Текущее время: 02:58. Часовой пояс GMT.
