Форумы » Работа с оборудованием » Прочее оборудование » Information about over/under soccer betting rules for newbies
reborn01790
22.11.2023, 03:11 | Information about over/under soccer betting rules for newbies
Understanding the rules of Tài Xỉu in football betting is crucial for effective wagering. It's a pivotal aspect for players' success, and comprehending these rules is imperative for winning. Without grasping the specific rules, victory becomes unlikely. Hence, follow Wintips' article below, as it provides comprehensive information, aiding in a quick understanding of the game's rules.
What is Over – Under?
Over – Under in English (abbreviated as O/U in betting odds), is a type of wager where the bookmaker sets a predicted number for a match. The player's task is to bet whether the actual result will be higher or lower than the number set by the bookmaker. Here, a result higher than the set number is Over (Tài), and lower is Under (Xỉu).
With this understanding, Tài Xỉu can be applied to various aspects. Anything where you can bet on whether the outcome will be higher or lower than a specific number can involve Tài Xỉu. In football betting, bookmakers often set Tài Xỉu odds on total goals, total corner kicks, total cards in a match, among others. To win at Tài Xỉu betting in football, refer to sure betting tips for additional crucial information.
Reading Over – Under Football Odds Accurately
In the Over – Under odds, the bookmaker provides a predicted number, known as the odds ratio. Here are common types of Tài Xỉu odds used:
Over – Under 0 Odds
This is the easiest type to read, specifically:
Betting Over and the match results in 1 goal: You win.
Betting Under and the result is 0 goals: You draw.
Betting Over and the result is 0 goals: You lose.
Over – Under 0.25 Odds
Also known as 1/4 odds or handicap odds. Read as follows:
Choosing Over, the upper team wins: You win.
Choosing Over, it's a draw: You win, but the Under bettor loses half the stake.
Choosing Under, the upper team wins: You lose.
Choosing Under, it's a draw: You lose, losing half the stake.
Over – Under 0.5 Odds
Also known as 1/2 odds or half-goal handicap. Reading these odds:
Choosing Over and the upper team wins: You win.
Choosing Over and the lower team wins: You lose.
Choosing Over and both teams draw: You lose.
The opposite is true for choosing Under.
Over – Under 0.75 Odds
This is also known as 3/4 odds, read as:
Choosing Over and the upper team wins by 2 goals or more: You win.
Choosing Over and the upper team wins by 1 goal: You win, receiving half the stake.
Choosing Over and the lower team draws or wins: You lose.
The opposite applies when choosing Under.
Understanding these Over – Under odds aids in making informed bets, enhancing the chances of success in football betting. Additionally, soccer tips sites also updates pre-match football betting odds for players.
The over-under betting 1 goal – 2 goals – 3 goals works like this:
For the 1-goal bet: The bookmaker predicts there will be one goal in the 90-minute match (including injury time).
If you pick Under and the result is a 0-0 draw, you win.
If you pick Under and there's one goal in total, it's a tie.
If you pick Under and there are two or more goals, you lose.
The opposite applies to choosing Over.
For bets like 2 goals, 3 goals, etc., the outcome is similar to the 1-goal bet, just with the bookmaker predicting 2, 3, or 4 goals.
The over-under 1 1/4 goals – 2 1/4 goals – 3 1/4 goals is a common type. Reading the 1 1/4 goal bet:
Choose Over, and if there are 2 or more goals, you win.
If there's 1 goal, you lose half of your bet.
If there are no goals, you lose.
The opposite applies to choosing Under.
The over-under 1 1/2 goals – 2 1/2 goals – 3 1/2 goals follows a similar pattern with no possibility of a tie. For instance, for 1 1/2 goals:
Pick Under and total goals of 2 or more, you lose.
Pick Under and total goals of 0 or 1, you win.
The over-under 1 3/4 goals – 2 3/4 goals – 3 3/4 goals operates similarly. For 1 3/4 goals:
Choose Under, and if there are 3 or more goals, you lose.
If there are 2 goals, you lose half your bet.
If there are 0 or 1 goals, you win.
The opposite applies to picking Over.
These various over-under bets have different odds and scenarios. Understanding them helps in making informed choices when betting on soccer. football tips app tools can assist in understanding and playing various soccer bets.
Rules for over-under betting in soccer:
Over: Total goals > bookmaker's odds
Under: Total goals < bookmaker's odds
If total goals match the bookmaker's odds, it's a tie.
This covers the basics of over-under betting in soccer. Understanding these rules can enhance your chances of winning. Good luck!
Текущее время: 03:00. Часовой пояс GMT.
